10 years agoHow to interface my verilog code with FFT ip core
I'm working on an application that involves the FPGA to take in an analog signal through its onboard ADC and perform the FFT using the altera ip core. So far, my understanding is the ip core g...
10 years agoInstantiate the code by copy and pasting the second half of generated file (that you've included above) in your higher level module. Substitute, as necessary, the signal names in the parenthesis for signals available in your higher level module to make connections to/from the FFT module instance. 'myFFT512_fft_ii_0' will be the instance name.
Cheers, Alex
