Altera_ForumHonored Contributor11 years agoHow to interface 1 MSPS ADC with processing module? Hello everyone, I have DE1-SoC board which contains 1 MSPS ADC, I am trying to take samples from ADC and process them. ADC Controller clock is 20 MHz and data is available every 16 clock cycles...Show More
Recent DiscussionsDuplicate_hierarchy_depth / duplicate_registerTiming analysis - long combinational pathAutomatically added negative node for TDS output doesn't work with Agilex 5Quartus 20.1std compilation fails for Quartus map - Device 10AS057K2F40I1SGQuartusPro 25.3 Crashed after using the Signal Tap Logic Analyzer
