liuyz
7 years agoHow to install tools for OPAE/HLS workflow under Intel Acceralation Stack?
Due to project needs and tools available, we are seeking help on setting up development for OPAE/HLS workflow under Intel Acceralation Stack framework for either PAC N3000 or A10 GX card. Currently,...
HRZ
7 years agoSome possible sources for your problem:
- Modelsim is officially supported only on RHEL/CentOS and SUSE (http://fpgasoftware.intel.com/requirements/19.3/).
- Intel HLS Pro requires GCC 5.4, but your log clearly shows that it is trying to link against GCC 4.7.4. Double-check the instruction in Section 1.1. of this document:
liuyz
7 years agoThank for your reply.
Yes, I have installed 32bits support on Ubuntu for ModelSim, and it seems I can start it standalone. But I will give RHEL a go.
For GCC, the installed one on my system is v5.4, and I set i++ to use the system gcc. For the v4.7.4 in the log, I have no idea, and it looks like from the ModelSim install folder. We use v17.1 ModelSim, and gcc 4.7.4 is part of the installation folder.
I think these are also parts of my query, which is the env doesn't hookup.
Have you successfully setup the HLS/OPAE flow?
