16 years agoYou can solve this in the way that you proposed.
An other solution in line with the global design tool flow of Quartus SOPC could be as follows: Each memory module with a different content (different .mif file) can be seen as a different component. So if you generate for every on-chip memory block with specific inital content a new MegaWizard module in SOPC, the whole flow is OK again. (Of course you have a point that it would not be necessary... But then you have to intervene in the design flow, causing trouble in the use of your design afterwards or by other people...)
