17 years agoinstead of using a text file, generate a VHDL package instead:
package mem_package is
type RamType is array (0 to 63) of bit_vector(31 downto 0);
constant MEM_INIT : RamType := (
x"0000",
x"0001",
......etc
end package mem_package;
Then in your source code you can just say
use work.mem_package.all;
signal myMem : RamType := MEM_INIT;
Then you can re-write or modify the package without having to worry about the source. The package could be generated via the same method you generated your ram_init.txt
