15 years ago
How to initialize 2-d memory?
Dear Forum,
I'd like to put a subsystem on a PLD which is a lookup table pretending to be the output of an ADC. I use the following verilog to initialize the lookup table.
`define W 10 /* ADC bit width */
`define N 40 /* modulo count */
reg [2*W-1:0] count_to_volt[0:N-1]/* synthesis ram_init_file = "memarray3.mif" */;
However, I'd really like 4 channels,
reg [2*W-1:0] count_to_volt_channel[0:3][0:N-1]/* synthesis What goes here? */;
but I don't know how to initialize the above 2-d memory array. At present my solution is just to use the first form four times with names count_to_volt1,...,count_to_volt4, but this is messy and it would be neater to use the 2-d memory. So, how do I persuade Quartus to initialize a 2-d memory?
Yours sincerely
Stephen
    Quartus can compreend farily sophisticated initial blocks.
    Something like this should do the trick:
    integer i, j;
    initial begin
    for(i = 0; i < 4; i = i+1) begin
    for(j = 0; j < N; j = j + 1) begin
    count_to_volt[i][j] = something
    end
    end
    end
    Dear rbugalho,
    That's very interesting because I did not know that one could use initial blocks in Quartus. Is this a functionality that has recently been added? Hitherto, I had guessed that the reason for .mif files was because Quartus did not understand initial blocks.
    Yours sincerely
    Stephen
    Dear rbugalho,
    Forget my last reply, I've just read the section entitled "Specifying Initial Memory Contents at Power-Up" in Volume I of the Quartus II handbook where it explains that Quartus can create a .mif file from an initial block for inferred memory.
    Yours sincerely
    Stephen
