9 years ago
How to infer BRAM fan-out
I am doing an OpenCL project of vector multiplication of VecA (M * 1) and VecB (1 * N) which produces a matrix MatC (M * N). I want to use a fan-out design which can support a 2-D processing engine array. Can I go like this to infer fan-our? :
https://alteraforum.com/forum/attachment.php?attachmentid=14222&stc=1
__kernel
void matMult() {
# pragma unroll
for(int x = 0; x < M; x++) {# pragma unroll
for(int y = 0; y < N; y++) {
MatC[x][y] += VecA[x] * VecB[y];
Any advice would be much appreciated!!
    You can achieve this type of systolic array design using the autorun kernel type and num_compute_units (Section 2.3 and 2.4 of Intel FPGA SDK for OpenCL Programming Guide). However, I would expect the same thing to be also achievable in a single kernel using loop unrolling, where the local memory buffers are automatically replicated by the compiler.
    Hi, thanks for your reply! Do you know any OpenCL systolic array design examples? (with code)
    There are some small code snippets in Altera's documents in the sections I mentioned above, but other than that, I do not know of any other public code showing the systolic array design.
    Hi, I tried the systolic array and it takes massive amount of BRAM and registesr (mostly for control overhead) which causes my design to be severely memory-bounded. But if I do the fan-out design, the way I unroll the loop cannot work out, it produces wrong output in hardware run. Do you have any idea how the loops should be unrolled?
    --- Quote Start ---
    --- Quote End ---
    Intel's FPGA systolic array example is a controlled material(using public code may not able to get best performance as not optimized for FPGA), and in the event user wish to have a copy that need to contact Altera representative separately.
    CloseCL
    Hi, Sir/madam,
    may I ask who should I contact if I would like to request for a copy?
    Lancer Chiang
    Hi Lancer,
    You can contact our sales/FAE as NDA is required.
    CloseCL
    Hi Sir/Madam,
    Many thanks! Is the copy an OpenCL implementation?
    Lancer Chiang
