14 years agoHow to import a Nios II SBT project with correct sopcinfo path
I copied a set of Nios II project including workspace and software folders made by someone else into my PC. There’s no problem to open qpf file with Quartus II, but the Nios II SBT for Eclipse couldn...
13 years agoHello,
I have the same problem ! When I give my project to others person, the software part is a nightmare on Eclipse THe program project is correct (I think) when imported but de BSP lib is not !!!! When you exectue generate, the tool indicate that the forled is not good !!!! This is because de Eclipse project is created in my folder machine and it is opened in my student folder machine. I think that this Eclipse error is a stupid error of programers !!! It impossible to export Eclipse project on other computer only if the folder destination is strictly the same as the source folder, this is never true !!!!!!!!!!!!!! Can some assistant can help us ? Regards
