How to implement and simulate FFT IP with SimuLink on FPGA (Cyclone V GX starter kit) error vsim-3033
I have emailed you a ZIP of the Q17.0 CV FFT IP generated design. You may do the following to simulate it:
- Unzip the files
- In Modelsim, change directory to the \simulation_scripts\mentor
- Type "source msim_setup.tcl"
- Type "ld"
- Type "do wave.do"
- Type "run -all"
- When message pops up asking if you want to finish the simulation, click "No"
You should be able to see the example simulation waveform. Please let me know if there is any concern. Thank you.
Hi, thank you so much for your help.
I did it and it works.
But what I really want is to create a testbench for several blocks in the same schematic, specifically a filter that I will connect to the input of the fft ip.
I actually get the error when performing the rtl simulation after generating the testbench for the fft.
This is what I do:
1.Generate -> generate testbench system
2. start analysis and elaboration
3. RTL simulation
4. Error in modelsim v3033:
** Error: (vsim-3033) c: /intelfpga/17.1/quartus/bin64/db/ip/blockt/submodules/blocktff_fft_ii_0.sv (59): Instantiation of 'asj_fft_si_se_so_bb' failed. The design unit was not found.
# Error loading design
# Error: Error loading design
# Pausing macro execution
# MACRO ./fft_on_top_run_msim_rtl_vhdl.do PAUSED at line 17
It is the first time that I work with this program and it is possible that I am doing something wrong, but I found another person with the same problem and he solved it but with the Pro version. I cannot do the same because I am using the standard version.
https://forums.intel.com/s/question/0D50P00003yyO6LSAU/fft-ip-core-and-modelsim
Thank you for your time,
Ignacio
