16 years agoI have just test some sources, and recognized that if I intend use SDRAM on DE2 I have to use SOPC build in NIOS system. So it will be ridiculous because I dont intent work on high level system with C of ASM, rather I just desired use SDRAM for my CPU design. So Nios II system apparently useless!
In other hand, I suddenly think about how Nios system can use SRDRAM and I discovered that It has built-in SRDRAM controller. So as the result, if I want to exploit SRDRAM on DE2 I have to construct this one by my own or use some available IP SRDRAM controler. Oh my god, now my question should be how to build a SRDRAM controller in quartus ?
