How to identify two different de0-nano boards by TCL (Quartus_stp) in a single host PC
Hi SyafieqS,
I found that “quartus_sh –qhelp” shows the same description as the Command-Line Tcl Manual from Intel.
I can distinguish two Altera USB-blaster(de0-nano) with different Ports [0,1,2,…].
Initially, USB Blaster(de0-nano) is reported as [USB-0]; plugging a new Altera device, the original one forces USB Blaster to jump to [USB-1], so quartus_stp connects to these two boards distinguish by different Port seems not a good way.
So I’m looking to change the device description from USB-blaster to such as de0-nano-01, 02, etc.
I tried to change the description by FT-PROG, by this article.
How to use two USB blaster cable in the same computer
But it didn’t work.
Both boards have programmed .jic files into EEPROM to boot up with my program. I wonder if I should change the description or serial number in Quartus, but I don’t know how to use it
