10 years agoHow to handle too many pins in the design when migrating from Cyclone to Cyclone III
Hi, I have an old design for EP1C12Q240 device that I want to migrate to EP3C25Q240. The old design uses all available IO pins i the device. Now I want to migrate the design to EP3C25 device, whic...
10 years agoHi,
as far as I know all signals in the top-level HDL entity must be assigned to physical pins. So my recommendation is to revise your top-level entity. Simply remove the signals that you don't need any more with the new FPGA. For input signals you must assign a default value, of course. If you want to keep both designs, you write a "wrapper" of your top level entity for the new FPGA, and assign the unused signals there. Best regards, GooGooCluster
