13 years ago --- Quote Start --- Don't listen to them!! Well it is reported on clk_scan register. Notice here that your clk_scan register is unlikely to be io register. If you want clk_scan to have less jitter then you better end it up nicely at io register before sending it out. --- Quote End --- Hi kaz, but counter actually can not generate very accurate clock. I try that, for example use counter to create a slow clock (40ns *256), the TimeQuest will tell me the real clock period, which is not exactly 10240ns. If you need very accurate clock, counter does not work very well. Yes, Clk_Scan is not outputted directly, it connects to a mux, the output of mux will be output to the chip. I will check what I can modify. Thanks very much!
