13 years ago --- Quote Start --- Yes, I found I used CK_Scan to trigger a module inside FPGA and now I changed it to clk_300ns. So you mean I should use positive edge of "clk"? I didn't understand this since clk_300ns will change exactly in the positive edge of clk, before clk posedge, clk_300ns maybe "0" and after posedge it became "1", why does this not cause metastable? --- Quote End --- aligned edges are in our favor just like the case of synchronous registers driven by same clock. Q output is always behind edge by tCO of register so don't worry. --- Quote Start --- And without PLL, how can I create the different rate clocks? Thanks very much for your time! --- Quote End --- use counter(s) to divide the clk rate into whatever patterns you want < clk rate. for example a counter that runs from 0 to 99 then you toggle a signal everytime it is halfway through at count 49 or set output to 1 at some specific counts and 0 otherwise.
