13 years ago --- Quote Start --- So you mean the warning is just warning. But leaving the output "blank" will not bring any negative effects on my design, right? --- Quote End --- If you don't want that output so be it. Your other outputs should not be affected unless you have some feedback chopped off from open output to an input. The design itself will be optimised accordingly since any logic dedicated to drive unwanted output becomes redundant.
