Altera_ForumHonored Contributor13 years agoHow to handle the no connection ports in a module? In some cases, I want to leave some input or output ports of a module no connection. E.g.: ModuleA modulea_1 (.in1(),.in2(),……,.out1(),.out2(),……); However, if I just program as above, to ...Show More
Altera_ForumHonored Contributor13 years agoIt warns you of dangling output and that is what you do anyway.
Recent DiscussionsFailed to run ip-setup-simulation:Compile option not saved (reversed to default)How to fix Error(23782): Failed to find an expected reportSSLC Login Issue – "You need to enroll" loop after OTP verificationFree Licence for Max+PlusII
