Altera_ForumHonored Contributor13 years agoHow to handle the no connection ports in a module? In some cases, I want to leave some input or output ports of a module no connection. E.g.: ModuleA modulea_1 (.in1(),.in2(),……,.out1(),.out2(),……); However, if I just program as above, to ...Show More
Altera_ForumHonored Contributor13 years ago --- Quote Start --- Thanks very much, kaz. How about output in verilog? --- Quote End --- Try empty brackets(can't remember well): out1(),
Recent DiscussionsFailed to run ip-setup-simulation:Compile option not saved (reversed to default)How to fix Error(23782): Failed to find an expected reportSSLC Login Issue – "You need to enroll" loop after OTP verificationFree Licence for Max+PlusII
