yjian16
7 years agohow to generate .aocx file from .sof or .bin file?
when I use aoc to generate the bitstream, but I will failed with Quartus_sh time out. So I use the .tcl script to run quartus compilation. It worked and generated the top.sof and fpga.bin. But I do n...
MuhammadAr_U_Intel
Contributor
7 years agoHi,
I will suggest to root cause the compilation failure.
Share your compilation log file, version of compiler /bsp you are using and kernel file for further investigation.
Arslan
