yjian16
7 years agohow to generate .aocx file from .sof or .bin file?
when I use aoc to generate the bitstream, but I will failed with Quartus_sh time out. So I use the .tcl script to run quartus compilation. It worked and generated the top.sof and fpga.bin. But I do n...
HRZ
7 years agoI know how to get bin from aocx, but not the other way around. The command to get bin from aocx is this:
aocl binedit $aocxfile get .acl.fpga.bin $binfile
Maybe you can try changing the third parameter in the command and see if you can get aocx from bin. However, if you always get a time-out at the end of the compilation process, you should probably try to find the reason for that rather than finding a work-around for generating aocx from bin.
