yjian16
7 years agohow to generate .aocx file from .sof or .bin file?
when I use aoc to generate the bitstream, but I will failed with Quartus_sh time out. So I use the .tcl script to run quartus compilation. It worked and generated the top.sof and fpga.bin. But I do n...
yjian16
7 years agoHi
thanks for your reply.
In fact the issue is that I can not generate the .aocx file by the command aoc. In the log, there will be the SERVER warning that the Quartush_sh process timed out. So the process is stopped by the errors. So my solution is to run the tcl script to finish the quartus compilatio and get the fpga.bin file. Although I got the fpga.bin, I have no .aocx file. So I want to know how to generate the .aocx file.
I try to use the aocl binedit command to update the fpga.bin in others .aocx file. I did no know that it will work or not.
