yjian16
7 years agohow to generate .aocx file from .sof or .bin file?
when I use aoc to generate the bitstream, but I will failed with Quartus_sh time out. So I use the .tcl script to run quartus compilation. It worked and generated the top.sof and fpga.bin. But I do n...
MuhammadAr_U_Intel
Contributor
7 years agoHi,
I am not aware of any command to generate .aocx file from .sof, I doubt there is any.
I can help you to root cause the issue coming while using "aoc" command to generate .aocx for example "aoc -c mykernel.cl -o bin/mykernel.aox -board=a10gx "
you may add "-v" to compile command to see detailed messaged in compilation.
Also specify compiler version / BSP you are using.
Arslan
