Altera_ForumHonored Contributor15 years agoHow to force Quartus to use M9K memory Hi, I have large array that I want to initialize with constant data: reg [9*1024-1:0] Data=9215'h....; that I want to use as m9k array, for example, as following: A<=Data[i*18+,1...Show More
Altera_ForumHonored Contributor15 years agolook up the Verilog ramstyle synthesis attribute in Quartus Help
Recent DiscussionsLicense issuejtagserver.exe causing BSOD together with ftdi driverWhen you double click on a word, the other instances do not highlight due to the Find Box being openJTAG error (Unexpected error in JTAG server -- error code 35 and Can't access JTAG chain)Tensor block usage
