12 years ago --- Quote Start --- Yes, Ive seen the fitter have no problems with the DSP blocks themselves, but then decides to put the next/previous register to the DSP half way across the chip to move it closer to the next/previous bit of logic. So adding in redundant pipeline stages pre/post DSP gives the fitter a bit of extra leeway on the timing. You can get the same problem with RAM Blocks too. --- Quote End --- I took this advice to heart and double-pipelined the entry and exit point (2 flops in a row on both input and output). The system still can't hit 320MHz. It's going global clock->DSP block->flop from global clock and it can't seem to meet 320MHz for setup on the multipliers (at least at slow corners--fast corners claim to pass). And we're not talking a small miss here. On a 3.125ns clock cycle it misses by almost a full nanosecond. I did check the datasheet for the chip (and checked that my device settings are correct), and it claims 370MHz is supposed to be the minimum on these. Is there some file where I can look at exactly what this thing is doing in the corners. That seems to be an *enormous* variation from fast to slow. 18x18 multiplier in 28nm and the system can't hold 320MHz while completely pipelined and with a constant on one input? Double pipelining on input and output and over half my delay is in interconnect? Something feels broken ...
