12 years ago --- Quote Start --- I remember someone saying that it takes time to get values into and out of the DSP blocks - so to do a multiple in logic probably requires that you add another pipeline stage (or two) somewhere. --- Quote End --- Yes, Ive seen the fitter have no problems with the DSP blocks themselves, but then decides to put the next/previous register to the DSP half way across the chip to move it closer to the next/previous bit of logic. So adding in redundant pipeline stages pre/post DSP gives the fitter a bit of extra leeway on the timing. You can get the same problem with RAM Blocks too.
