12 years ago --- Quote Start --- I didn't yet hear any results when enforcing logic implementation of the constant multipliers for the present problem. --- Quote End --- Sorry for the lag, but I've been fighting a couple different issues. Enforcing the logic implementation removes the multiplier usage but loses significant speed. I would have to hand code a compression tree to win back enough speed. I may do that, at some point. If so, I will add to this post. However, unless I hit a speed wall, I probably won't do that. I'm finding that I am more than a bit underwhelmed at the speed performance of the Arria V's. I did not expect 250+MHz in Verilog to be this problematic in a 28nm technology chip.
