12 years ago --- Quote Start --- Timing is the issue, primarily. I'm shoving things around at 150MHz to 200MHz on an Arria V. Not impossibly fast, but one definitely has to be alert to what is actually happening in synthesis. The multipliers want to finish the carry-propagate add before giving the result. Unfortunately, I have an add accumulation tree right after the multiplier, so the carry-propagate is effectively useless *and* soaks up a big chunk of time. I'd rather dump the final carry-save state and let the accumulate tree absorb it. --- Quote End --- Well I regularly get timing problems on mults (stratix iv @ 368MHz) then I realise what to do: put a pipeline register after mult result (apart from block's registers). This makes a big difference. I was afraid at times that this pipe may be repacked into blocks but it never happened apparently. It seems that -otherwise- routing is too bad from these mult blocks to the fabric. If you get latency problems then you might discard an internal block pipe if applicable. On the other hand I must confirm that with fpgas we regularly have constants into mults e.g. coefficients and we don't target designing mults as simple shift/add. DSP blocks are usually fast.
