12 years ago --- Quote Start --- However, if one input is constant we don’t need that apart from shift only(or plus adder). So the two cases are distinct from design perspective. The original post is not obbssesed with shift but wants simplified design. Personally I prefer DSP blocks. I might target one or so coeffs (say) as power of 2 to save few mults just in case. --- Quote End --- Timing is the issue, primarily. I'm shoving things around at 150MHz to 200MHz on an Arria V. Not impossibly fast, but one definitely has to be alert to what is actually happening in synthesis. The multipliers want to finish the carry-propagate add before giving the result. Unfortunately, I have an add accumulation tree right after the multiplier, so the carry-propagate is effectively useless *and* soaks up a big chunk of time. I'd rather dump the final carry-save state and let the accumulate tree absorb it.
