12 years agoAs a point of reference, Stratix V now allows each DSP block to have 8 fixed coefficients that can be muxed from coeff_sel lines, and if Im reading correctly the coefficients can be up to 27bits. This might actually be a way to avoid the Ram based multipliers that ive seen used for higher speed designs when the multiplier value is fixed.
