How to fix timing issue
I use Quartus prime with proper sdc constraint to program FPGA(there are several clock/generated_clock in ny design) . However it still have timing violation in the result. When I add/remove some signals to/from signaltap II, the result could be good(not always) . Is there a recommand suggstion to solve this problem?
1 Reply
- KhaiChein_Y_Intel
Hi echen73,
You have to check the timing report and see what are the paths that violated timing.
Timing Analyzer Quick-Start Tutorial: https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_tq_tutorial.pdf
Intel® Quartus® Prime Timing Analyzer Cookbook: https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/manual/mnl_timequest_cookbook.pdf
Introduction to Timing Analyzer(Pro Edition): https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug-qpp-timing-analyzer.pdf
Introduction to Timing Analyzer(Standard Edition): https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug-qps-timing-analyzer.pdf
