AChri1
7 years agoHow to fix DDR2 memory in MAX10 giving error 17044 when compiling.
I get the following : Error (17044): Illegal connection on I/O input buffer primitive max10_test_ddr3:inst|max10_test_ddr3_mem_if_ddr2_emif_0:mem_if_ddr2_emif_0|max10_test_ddr3_mem_if_ddr2_emif_0_p0...
BoonT_Intel
7 years agoHi,
If you are not setting the IP QIP file as top level. Then you need to connect all memory interface signal (ADD/CMD and DQ/DQS) to your top level file. the IP will require you to connect all interface pin to physical I/O to pass fitter.
