16 years ago --- Quote Start --- In Quartus II go to the MegaWizard plug-in Manager (in Tools menu). Then click next, and in I/O folder you have the ALTPLL megafunction. Select the FPGA target and put the name of the pll block as it will appear in your project, click next, and then select the parameters of your PLL. Once it is finished, you can add it to your design. Jérôme --- Quote End --- Hello, Jérôme, I think you are getting what my problem is. But could you please give more details on how to add the PLL into my design after I have instantiated it using MegaWizard plug-in Manager? Thank you~! Regards grit
