16 years agoIn Quartus II go to the MegaWizard plug-in Manager (in Tools menu). Then click next, and in I/O folder you have the ALTPLL megafunction. Select the FPGA target and put the name of the pll block as it will appear in your project, click next, and then select the parameters of your PLL.
Once it is finished, you can add it to your design. Jérôme
