JPye
7 years agoHow to eliminate sporadic errors on Stratix-V designs?
Our company makes products using a board we designed which has two Stratix-V parts. We have various FPGA designs that operate on this board already. We were recently motivated to change and add some ...
JPye
7 years agoJan,
Thank you for the reply. As you say large designs do require more power and we are checking into that as a possible cause. It is in our pipeline to get a power source that supports higher current to see whether it makes a difference. As it is we don't see dips in the core voltage when we put a scope on it. And the temperature of the part does not measure as excessive. We do have heat sinks.
John
JKastil
7 years agoHi,
I see you write several time about Core voltage but you describe trouble with I/O interfaces. Did you check also other voltage rails (transceivers can behave weird if the voltage is not correct, particularly during their calibration and reconfiguration)?
Jan
