14 years ago
How to efficiently construct architecture with large amount of identical components
Say an architecture has got 500 ALUs having exactly the same structure. Even if I use COMPONENT in VHDL still I need to instantiate each one of them which is huge amount of labouring...
So what is the efficient way of instantiating the same component for many times?
Thanks a lot!
1 Reply
    Draw yourself a picture and try to figure out an indexing scheme for the nets connecting the components. Once you have that, you can create a 'generate' loop where you instantiate the components.
    As an example, look at the multiplexer posted in this thread:
    http://www.alteraforum.com/forum/showthread.php?t=35540
    There's a PDF showing the indexing scheme and then source showing the implementation. The same concept applies when creating adder-trees, bit-error-rate counters, etc.
    Cheers,
    Dave
