SPraj4
6 years agohow to "duplicate nodes" and "reduce levels of combinational logic" to remove negative slack in timing analysis Quartus??
I am trying to design ddr3 interface using Qsys in Quartus Prime Lite Edition for cyclone V GT (5CGTFD9E5F35C7) Development board. While running timing analysis, I am facing setup and hold violation...
sstrell
6 years agoI mean you should take the example project, make sure it works, then customize it for your own use. Use the project itself as a base. Don't try to copy the settings you see in the example project into your own because you'll inevitably miss something.
#iwork4intel
