how to "duplicate nodes" and "reduce levels of combinational logic" to remove negative slack in timing analysis Quartus??
What do the errors say?
So you're saying from this download (http://fpgadownload.intel.com/outgoing/devkit/13.0/cycloneVGT_5cgtfd9ef35_fpga_v13.0.0.1.zip) you opened the "golden top" project, compiled it, and got synthesis errors? Since the download is for an older version of Quartus, you would probably need to update the IP, but that project should be the starting point.
#iwork4intel
- SPraj46 years ago
Yes I used that download but not compiled "golden top" . Instead I opened "q_sys_hmc.qsys" from "board_test_system" (examples\board_test_system\qts_ddr3\c5gt_ddr3\ ). From there opened ddr3 uniphy IP and made a preset with exactly same parameters and settings.
And further added that preset to my project and compiled it and got synthesis errors. You said that:
"Since the download is for an older version of Quartus, you would probably need to update the IP, but that project should be the starting point."
when I opened the example project I updated the IP, but what you mean by "that project should be the starting point"??
