18 years agoHi, I have found the related info in QuartusII 7.1 handbook.
In fact, I have read it before, but I can't find any answer for my question above. Just for the simple question above, could you answer directly, I'm a little confused. --- Quote Start --- The phase shift between CLKA & CLKB is based on fitting result, so they are unrelated clocks, right? And so I should cutting the path analysis between them? --- Quote End --- I myself think that: Thouth the phase shift between CLKA & CLKB is based on fitting result, but TimeQuest should also know the phase shift, so it should create tge generated clock automatically. Thanks...
