11 years ago
how to define a function in quatus?
I created a file named user_defs.vhl, the contents as below:
LIBRARY ieee;
USE ieee.std_logic_1164.all;
PACKAGE user_defs IS
Type Clock is (int, ext);
Type Trig is (manual, auto);
function spi_adc_wr_rd(input_dat: bit_vector(15 downto 0); input_clk: std_logic) return bit_vector(15 downto 0);
END user_defs;
PACKAGE BODY user_defs IS
Function SPI_ADC_wr_RD(Input_dat: bit_vector(15 downto 0); Input_clk: std_LOGIC) return bit_vector(15 downto 0) is
variable tmp: bit_vector(Input_dat'rang);
begin
tmp <= Input_dat;
return tmp;
end;
END user_defs;
I want to invole this function of SPI_ADC_wr_RD in another VHDL file,
USE work.user_defs.all
but when I compile this project,
it always displays error as below, even I do not invole this function.
10479 VHDL error at user_defs(9): indexed name type is used but not declared.
I am using 32-bit Quartus 13.1,
please give me support.
thanks!
Br
jjl3
    Is that the full code? it has a typo in it:
    you need input_dat'range not rang
    Also, what are you expecting this function to do? currently. it does nothing except return the input. And the clock parameter does nothing.
    Apart from the typo (rang -> range) and also tmp being assigned as a signal rather than a variable, the source of the error message given by Quartus is probably that you define the return type as a bit_vector(15 downto 0). This is interpreted as an array of bit_vectors (thus the mentioning of indexed name type). If you remove (15 downto 0) from the return clauses this compilation error should be cleared. That is:
    Function SPI_ADC_wr_RD(Input_dat: bit_vector(15 downto 0); Input_clk: std_LOGIC) return bit_vector;
    END user_defs;
    Function SPI_ADC_wr_RD(Input_dat: bit_vector(15 downto 0); Input_clk: std_LOGIC) return bit_vector is
    /J
    --- Quote Start ---
    END user_defs;
    /J
    --- Quote End ---
    Thanks! you are right!
