Altera_ForumHonored Contributor12 years agohow to decrease compile time. when a compile a project ,more than ten thousands lines. it used more than 3 hours. what i can do to avoid this. use good cpu? i used Xeon 3.4G 24G memory. optimize Quartus setting? but i...Show More
Altera_ForumHonored Contributor12 years agoWhat is too long? 3 hours sounds pretty good for a stratix V.
Recent DiscussionsAutomatically added negative node for TDS output doesn't work with Agilex 5Quartus 20.1std compilation fails for Quartus map - Device 10AS057K2F40I1SGDuplicate_hierarchy_depth / duplicate_registerQuartusPro 25.3 Crashed after using the Signal Tap Logic AnalyzerIs Quartus Prime Pro 22.4 Compatible with Stratix 10 NX Series Device 1SN21CEU2F55E2VG?
