18 years agoFirst of all, you have wrong assigment here : az_addr <= (other 0); . It should look like this : az_addr <= (others => '0'); . I don't know how do you assign values to signals, but you should write a state machine to controll read and write process. From your code I can say, that section:
az_addr <= (other 0); az_rd_n <= '0'; --read enable az_wr_n <='1'; --write disable clk and reset_n signal are also assigned and az_cs <= '1'; az_be_n<="11111111" --data mask disable write operation az_data<="11111...1" -- 64 bits az_rd_n <= '1'; --write enable az_wr_n <='0'; --read disable clk and reset_n signal are also assigned and az_cs <= '1'; az_be_n<="11111111" --data mask disable assigns values at the same time to all signals. It would be easier if you could paste your exact code (if the code you have shown isn't the exact code you're using).
