18 years agoIt depends on used memory chips. In SDRAM you can set a parameter called latency and it will determine number of clock cycles between read request and data appearance on the memory bus. Usually this takes from two to four clock cycles. If you want fast memory access you can just rise memory clock frequency. Of course, I assume that memory controller will be synthesised in your FPGA :] Another soluction is to use SRAM memory. It is faster than SDRAM, but has less capacity.
If you want to know how to implement SDRAM controller in VHDL I will present here one of possible soluctions ;) Let us assume that your FPGA has a 50 MHz clock and you want to strobe SDRAM with same 50 MHz clock. So: SDRAM_ctrl : process (clk,rst) is begin if rst='1' then --assumed reset signal active high counter <= "0000000000"; --counter is 10 bit std_logic_vector elsif rising_edge(clk) then --you can use falling_edge(clk) if it's more convenient if counter = 10 then --this is just an example. The point is that counter SDRAM_cs <= '0'; --precisely determines moments when RAM control end if; --or data signals should change if counter = 11 then --for precise timing waveforms refer to your SDRAM SDRAM_ras <= '0'; --datasheet end if; end if; end process SDRAM_ctrl; Hope, I helped you ;)
