MohdAnnuar_S_Intel
7 years agoHow to debug jtagconfig not detecting JTAG hardware?
This is seen on quartus prime pro Linux version 16.0.0.211 installed on SLES 11 with udev rules as below: ATTR{idVendor}=="09fb", ATTR{idProduct}=="6810", ACTION=="add", RUN+="/bin/sh -c 'chmod 666 ...
MohdAnnuar_S_Intel
7 years agoHi YL,
I have checked the steps in the link. In case programmer for statix 10 GX, I am using the USB Blaster II cable and I believe the programmer circuit is integrated into the development board. I connects only USB cable from host server to the card's micro USB receptacle. For power requirement, I believe it is handles by the board's power supply.
I also tried setting down TCK clock to 6Mhz using jtagconfig. However the command return no JTAG chain found.
In term of quartus installation, it is being installed in NFS disk and I invoke the program from the installation path after setting the appropriate LM_LICENSE_FILE variable.
Annuar
