15 years agoAnother idea is to use an enable and "enable" it on every other other clock. This way you keep the same clock, and don't have to slow down your circuit. However, if you can get by with 25MHz like you mentioned that's always an option. Sometimes KISS is the best way to accomplish something, unless you have time to experiment and want to try a few alternatives.
