That is strange, it should be there with the default installation. This may sound elementary, but when you pull up the programmer, are you selecting JTAG? Otherwise the file selctor won't even look for *.sof.
Not much help, I've never seen this before. - Altera_Forum
Have you tried searching in the output_files folder instead of the main folder?
HI
created a simple test code and compiled it completely, but no *.sof, *.pof files generated in project directory and output files directory. It seems that my setting is wrong? do you know what I should set for these output? Is this license issue ? using qurtus2 web edition v13.0. Thanks Vraifluss - Altera_Forum
13.0 was not , but 14.0 can create the *.sof. Still do not know why??
Anyway I can use 14.0 web edition. Vraifluss
