10 years agohow to create a simple alarm clock using verilog code and run it on FPGA board?
Hello everyone. i'm suppose to create a simple verilog based alarm clock project and the program it to a FPGA board to obtain the output. As i'm a beginner to this and i have no knowledge in programm...
10 years agoHello. I had tried to program an alarm clock with the help of my tutor. But, i'm unable to reset the clock once it is started. Can anyone guide me through this. Thanks In advance.
Nurda
3 years agoHello. Help me urgently. Does this code you wrote have a schema? And can you briefly explain to me what code is responsible for what. Post the code if you solved the problem with the reset?
