10 years agohow to create a simple alarm clock using verilog code and run it on FPGA board?
Hello everyone. i'm suppose to create a simple verilog based alarm clock project and the program it to a FPGA board to obtain the output. As i'm a beginner to this and i have no knowledge in programm...
10 years agoYou can start by drawing out flow chart on how your alarm project should behave. Then code it. You can use QII Analysis & Synthesis compilation to help check the code syntax. To simulate the functionality, you can use Modelsim Altera Starter edition which is free.
