12 years ago --- Quote Start --- To work as expected, the loop must use a variable instead of a signal. Otherwise only the last iteration will be performed. --- Quote End --- Thanks. I realize that a very good way to do it is to use structural. Then, I just connect them together. It's also for obviously programming I'll build a library for a adder.
