Norick
7 years agoHow to connect a Clock-Controlblock with a ADC-PLL?
Hello When using the PLL_ADC_internal followed by a ClockControlBlock which goes to the internal Dual-ADC from the Max10, it is not possible to connect it as shown below. If so, Quartus can't...
a_x_h_75
Contributor
7 years agoIf Quartus says 'no' then I suspect it's not possible, although I am a little surprised. I may well try this later...
If you can feed the clock off the device and back in on another pin I'm suspect you'll be able to realise a solution.
Cheers,
Alex
- Norick7 years ago
for whatever reason I can't use the Clock-Controlblock in between the PLL and the Max10 ADC I will try to use the 'reset' of the PLL as you mentioned. Do you know how to assign
for example PLL1 with FPGA clock input CLK1?
