Norick
7 years agoHow to connect a Clock-Controlblock with a ADC-PLL?
Hello When using the PLL_ADC_internal followed by a ClockControlBlock which goes to the internal Dual-ADC from the Max10, it is not possible to connect it as shown below. If so, Quartus can't...
a_x_h_75
Contributor
7 years agoPut the PLL in reset. Given you don't appear to use the clock out of the PLL for anything else I can't see this being a problem.
Gating a clock to an internal block (internal ADC) may well be something the MAX10 routing cannot accommodate. If this was to an external pin I wouldn't anticipate a problem.
Cheers,
Alex
