How to connect 32bit master to 8GB ddr memory using Qsys interconnect.
- 3 years ago
I recommend the Address Span Extender component. It allows you to set a window into a larger memory space. The example given in the documentation is your use case:
For example, an HPS subsystem in an SoC device can address only 1 GB of an address span within the FPGA, using the HPS-to-FPGA bridge. The Address Span Extender enables the SoC device to address all the address space in the FPGA using multiple 1 GB windows.
